6885P5H
Hi. First of all I know that this laptop is pretty recent for the forum (late 90's, Pentium, Windows 95), so feel free to move it to the off-topic section if its presence here is too offensive.
This laptop worked until I tried it one day and it didn't anymore. When I turn it on the status indicators for the keyboard light up and then shut down, the same thing happens with the HDD activity indicator during the drive's seek test, and that's it, the laptop doesn't go any farther in its boot sequence. The screen never turns on and the keyboard is unresponsive. The reset button works. Interestingly the computer shuts down 30 seconds after you tell it to, and then blinks an error code with the DC IN indicator (represented on the battery's bezel by a power plug). The code is 1 long-4 shorts-1 long-2 shorts. According to the documentation that I have found online for other Toshibas, this either means error code 21h or 84h. 21h is "The main battery charge current is more than 6.05 A" and 84h is either "BGVSNS voltage is not more than 1.62V when the computer is suspended." or "BGVSNS-B1P voltage is less than 0.68V when the computer is suspended.". Of course as my model is 320CDS this information could be erroneous but it seems like it could be a power-related issue, if the error code is correct.
Does someone know what the problem is?
Update: It doesn't blink an error code anymore. Good thing that I documented it.
Update: I have disassembled the computer and found that one of the two internal batteries has corrupted leads. The plug of the battery exploded when I tried to disconnect it. The battery in question is the larger one, with the two-pin plug. The colour of one of the leads of the connector is duller, but I found no other signs of corruption in the circuit.
Anyway, seems like I should scour my things for batteries and remove them.
I wonder why the laptop has two batteries? One for the settings and one for the clock?
