andy
The floppy drive in my T3200SX is bad, and I suspect I could replace it with a standard floppy drive if I built an adapter cable. Does anyone know the pinout?
TABLE B-9 FDD Connector Pin Assignment
ÚÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄ¿
³ Pin ³ Signal ³ I/O ³ Pin ³ Signal ³ I/O ³
ÃÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄ´
³ 1 ³ VCC ³ O ³ 2 ³ INDEX;000 ³ I ³
³ 3 ³ VCC ³ O ³ 4 ³ FDSELA;000 ³ O ³
³ 5 ³ VCC ³ O ³ 6 ³ DSKCHG;000 ³ I ³
³ 7 ³ VCC ³ O ³ 8 ³ READY;000 ³ I ³
³ 9 ³ NOTCH0;000 ³ I ³ 10 ³ MONA;000 ³ O ³
³ 11 ³ LOWDNS;000 ³ O ³ 12 ³ FDCDCR;000 ³ O ³
³ 13 ³ GND ³ ³ 14 ³ STEP;000 ³ O ³
³ 15 ³ GND ³ ³ 16 ³ WDATA;000 ³ O ³
³ 17 ³ GND ³ ³ 18 ³ WGATE;000 ³ O ³
³ 19 ³ GND ³ ³ 20 ³ TRACKO;000 ³ I ³
³ 21 ³ GND ³ ³ 22 ³ WPROTC;000 ³ I ³
³ 23 ³ GND ³ ³ 24 ³ RDDA;000 ³ I ³
³ 25 ³ GND ³ ³ 26 ³ SIDE;000 ³ O ³
ÀÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÙ
CABLE PIN OUT
Toshiba EXT FDD SIGNAL NAME Floppy Drive 34 Pin
CONNECTOR IDC CONNECTOR
PIN PIN
01 Ready 34
02 Index 08
03 Track 0 26
04 Write Protect 28
05 Read Data 30
10 Motor Enable A 10
11 Motor Enable B 16
12 Write Data 22
13 Write Enable 24
15 Select Head 1 32
16 Direction 18
17 Step Pulse 20
23 Ground (must be connected) 23
25 Ground (must be connected) 25
Yup.Thanks, that looks like the standard 26 pin laptop floppy pinout.
Not much worse than many other laptops; just unplug the other end.I have to say that this is one of the worst put together systems I've seen. The fact that the screen is hard wired to the motherboard makes it very difficult to work on.
Yup.
