twolazy
Older machines sometimes require a key combo to enable external displays. Should be like fn+f3 or f4
I tried two different external LCD monitors, and two different VGA cables. Any ideas? Can you only connect an old CRT screen as an external VGA monitor (I doubt it)?
The VGA connector and VGA signals are well-defined, as are the two standard resolutions (640x480@60 and 720x400@70). Higher resolutions were eventually standardized by VESA, but not from the beginning.While the VGA connector is a well defined standard, the VGA resolution is not. IBM did define a standard of 640x480x16, but VGA was also backwards compatible with older EGA, CGA and MDA modes.
The standard resolutions were always supported and rarely deviated from. Even today, any HDMI-certified device must be capable of handling 640x480@60 (as well as 720x480 or 720x576, depending on region).As VGA got cloned by third parties, a dizzying array of different resolutions, color depths and refresh rates followed.
For VGA, this is just wrong. The EDID data is sent from the monitor to inform the system about the monitor capabilities.Many newer monitors expect EDID data or they won't even try to display the incoming video signal.
