ardent-blue
- Joined
- Jan 1, 2015
- Messages
- 766
Folks, I am getting curbstomped. I have been trying to develop the grand unification theory for PS/2 Configuration Memory varieties, got the RTCs, external NVRAM [SRAM], and the devil cursed RTC Modules [like the DS1287] identified by system.
Plenty of published stuff on accessing the defined registers in the RTC. It seems that writing to / reading from the SRAM portion of an RTC [aka "CMOS"] or ritin'/readin' the external SRAM [aka "NVRAM" or "Extended CMOS"] is done to addresses, not registers.
WHAT is the form of the header? This was complexified when IBM dreamed up the NVRAM Dynamic Data Area in early 1990 [only a partial TDB...]. Note that the block is NOT of a fixed length anymore. How is this set up?
Function: 09h — Write to CMOS RAM from the ABIOS seems to resemble a structure, but this may be the older one. Also, looking [confuzedly] at the Undocumented PC, 2d Ed. Wondering if the utilities only support 2k and 8k NVRAM, while there are a few 4k implementations out there [8553 and 8555LS ?]. It would not strike me as impossumble for one of these rare 4k systems to bring the CMOSVIEW utility to a smoke-belching stop.
I did not sleep at a Holiday Inn Express last night... MAJ Tom has divulged some details, but the 95 Tech Ref only concerns itself with the CMOS, no mention of Extended CMOS.
NOTE: While czeching each model's page to verify the RTC / NVRAM chipset, I noticed that while the 25MHz 8580 Type 3 system board uses the Motorola MC146818AFN RTC/CMOS, it also uses the Sanyo LC3664NML-12 8Kx8 SRAM. Only 8570 or 8580 to use the combo. All others use 2kx8 SRAM.
