Vinpaq
Just to put it out there, I have all softpaq zipfiles on a server. You can find them here:
If you read the first post, the softpaq files will not write in DOS.Just to put it out there, I have all softpaq zipfiles on a server. You can find them here:
Disregard my FTP skills are rusty.Trixter I get "
Forbidden
You don't have permission to access /pub/drivers/Compaq/Portable/Software/cpaqd212.raw on this server."
I have a 300mb MFM drive in one of my portable I's. I dont remember the details of how I set it up years ago.. But it can certainly take a hdd. I thought I remembered setting a Drive TYPE number somewhere.. But I cant honestly say.The original portable had no support for HDD, so the floppy may not have supported low level format.
I’d imagine the floppy with the portable plus would have had a utility. I think the first controller only supported one drive type, so there was probably no setup other than formatting it.
I’ve got a manual and disk for a deskpro that mentions hdd, so I need to see if I can image that. It wasn’t kept in a climate controlled environment so hopefully it’s good. I would expect it to work on portable with a hard drive too.
I got the RAW file and wrote it out. Version 2.12. I guess there is no setup or cmos. I assume hard drives are configured via switches and debug the MFM controller like on a 5150.
