TRS-80 CM-1 Monitor
Greystar
Hey all, does anyone happen to have a TRS-80 CM-1 Monitor (Model No. 26-5112) that they'd be willing to open up the case on and take a picture of the bottom of the board in for me?
I opened mine up to double check that nothing was obviously wrong before powering it up and I noticed it had that old sealant/silastic the tends to become conductive over time. I checked it with my multimeter and it was indeed conductive for some of it. It had a very high resistance, but I wasn't wanting to risk it causing a problem in the future, so I set about getting it all removed and using some non-corrosive silicone in its place.
Well, like a dumb-dumb before taking pictures of the board, I removed a resistor that was on the bottom of the board near the flyback transformer and now I'm not 100% sure which two pins the it was soldered to on the bottom of the board. I'm confident in one of them, since looking at the solder it's obviously been reflowed and I think I know the other one, but I'd rather not risk damaging anything. I'm marked the two points where I think it was soldered to. I'm confident in the one on the left, but not the right. The one marked on the right looks like I might have melted it with my soldering iron, but I'm not sure.
Looking closer it might have gone to pin 5 on the flyback. There's a hole in the solder blob that looks like it could have had the leg of the resistor in there and it just didn't heat up enough to flow back in and fill the hole. Pin 5 on the flyback is a ground pin when I check with my multimeter. The point I'm confident about goes directly to pin 6 on the flyback. The arrow on the right goes directly to pin 3 on the flyback.
There is a resistor installed there on the top side of the board at the two points marked in the attached image (the one on the bottom is a 1.8 MOhm and the one on the top side of the board is 330 kOhm).
I've not been able to find any pictures of a CM-1 that's been opened up. The board and tube were manufactured by Mitsubishi. The P/N on the board is 240A15701 (I think it's the former). I think the Mitsubishi model number is G0194V-0. That shows up on both the main board and the neck board.
Well, I need some help (will do a separate post on that) with a CM-1 too, but the reference "Greystar" put a link to is NO LONGER AVAILABLE!
I have the service manual on Tandy2000.com
Thank you for the offer, someone actually sent me some information, but it turned out that I did not have a CM-1 monitor but rather a 26-1202 monitor (I didn't know there was more than one model of these for the TRS-80 Model 1 computer); which I do not see on your website, but someone made available to me. If you look for my recent post, you can see on that.
Hey all, Archive.org decided to nuke the CM-1 service manual. I've put it up on my website, so now it's available there.
Sadly, I still haven't been able to solve the original problem. Given that this is a bodge and it's not on the schematic it'll probably work just fine without it, but I'd prefer to put it back how it was.
No one has a CM-1 they'd be willing to open up and snap a picture of the bottom of the mainboard around the flyback?
Sadly my CM-1 does not have a resistor fitted where yours did. I know this isn't a clear picture but there was nothing at all near the flyback.... just one diode in the very bottom edge. I only took close up pictures of the area where all the components were installed on my board... but in the end I cleaned off all the circuit glue crap without removing any components.
I only had corrosion on two parts, one thing on the neck board and that diode near the flyback.... and with the diode, it was just where the diode connected, so I was quickly able to re-attach that one. The neck board corrosion was on a ferrite bead they added, and it didn't break anything, just exposed some copper so once the glue was removed I just used laquer to cover that up.
Thanks Adrian! I appreciate you following up. As I said on Patreon, I'm glad the service manual was useful for you video!
My 2nd CM-1 also has nothing there, so I feel like it's safe to assume it's not a huge deal to omit it. I have a feeling it's a bleeder resistor for the flyback/tube, but not knowing which pin is the one it should be on, I'll run the risk of the tube not discharging as quickly.
What is that bodge in the lower righthand corner of your picture? My board doesn't have one there. I'd check my 2nd monitor, but it's in my storage unit at the moment.
