Hi
I've recently got myself a model 4. Seems overall good condition. I have already received a frehd kit and a U72 Pal from ian mavric.
HOWEVER!
before I've even started to build or fit those an intermittent boot problem has got much worse. It worked when i first got it, then a week later it suddenly crashed to a garbage screen, and would only boot 1 time out of 10. It no longer boots at all, just sits there with a corrupted display. The drive spins for 30 seconds or so and.. thats it. Same if I hold down break while powering on.
Once or twice today it has spun the disk for 10 seconds or so, stopped, then respun the disk, then again. But thats rare.
I have reseated every IC I can - no change
Ive temporarily swapped out the 4164 rams - (though i dont know if my replacements are good or bad) - no change.
One time I swapped out the U70 and U72, put in the extra 64k ram and it worked. But one time only. So i have reverted back to stock and its exactly as it was.
I note the corrupted display is almost exactly the same each time (see pic) except the time it 'almost' booted when only half the screen was garbage, the rest blank.
Ive also swapped the z80 for a new (but also untested) Z80 - no change, exactly the same.
Can anyone offer any advice or help please? steps to eliminate?
TIA, Iain, UK.
HOWEVER!
TIA, Iain, UK.
