I was given a Model 4 which keeps blowing the video board fuse. I was told that something "shorted" in the power supply (who knows?). The power supply fuse does not blow, and if you disconnect the PS and give it AC, the output voltages look ok. If you hook up everything except the connector to the video board and power it up, the voltages on the PS board still look good, the machine spins the disk a while, then stops, and if you press reset the disk spins again, so I think the motherboard may be at least partially working, if I can get anything out of the crt. Given what the previous owner told me, since I had another power supply, known good. I tried swapping it in place of the original PS, but no change. So I bought another video board on ebay advertised as "model IIIII/4" video board. It's a model III board, and while the edge connector and the plug on the end of the crt fit, the connectors are different to the coils around the crt some distance toward the screen from plug (I am ignorant about crts). The model 4 has a 4-pin connector to the video pcb for the coils and a bullet connector for ground, while the model III video board has 4 spade lugs. Can anyone help with (1) debugging the model 4 video board? or (2) adapting the model III video board to work on the model 4 crt? Thanks very much.
