Hi all,
I’m having issues with the 64-256KB motherboard in my IBM 5160. It was working fine a few months a go but when I went to power it on recently, the fan turned in the PSU but nothing came up on the display, instead it made a continuous buzzing sound.
I’ve taken the motherboard out and done the following, none of which have made a difference,
-Replaced Bank 0 with known good RAM
-Swapped in known good 8088
-Checked continuity for the 40 8088 pins (top of IC to solder joint on bottom of board)
-Swapped in a known good 8284A clock generator
-Checked resistance with the board disconnected, as per http://minuszerodegrees.net/5150_5160/MDC/no_beeps_2_2.htm
+5v = 900 ohms
-5v = OL
+12v = OL
-12v = OL
-Checked voltages with board powered on, from known good PSU,
P8-Pin1 = 5.01v
P8-Pin3 = 12.43v
P8-Pin4 = -11.16v
P9-Pin3 = -5.11v
P9-Pin4 = 5.04v
P9-Pin5 = 5.04v
P9-Pin6 = 5.04v
-Replaced U18 with known good Landmark ROM. Nothing comes up on the display, although the buzzing starts straight after power on, whereas with the normal bios it takes a few seconds to start.
-I’ve checked that the CPU RESET line gets taken low and there seems to be a CLK signal at Pin 19 of the 8088.
I’m not sure what else to try at this point. It’s obviously failing very early on, as neither the POST nor Landmark appear to start executing, and I’m guessing the buzzing is because of the following,
http://www.vcfed.org/forum/showthread.php?69921-5160-XT-motherboard-problem&p=571673#post571673
Here is a video of it starting up,
https://imgur.com/gallery/nZ9wZGE
Sorry – just checked one last thing as per here,
http://www.vcfed.org/forum/archive/index.php/t-15315.html
S0, S1 and S2 are all held high – so the 8088 is stuck in the HOLD state?
Any pointers much appreciated - Thanks!
+5v = 900 ohms
-5v = OL
+12v = OL
-12v = OL
P8-Pin1 = 5.01v
P8-Pin3 = 12.43v
P8-Pin4 = -11.16v
P9-Pin3 = -5.11v
P9-Pin4 = 5.04v
P9-Pin5 = 5.04v
P9-Pin6 = 5.04v
