Chris Hafner
Hi all,
I've been trying to search the forum, search the web, and wade my way through the long XT-IDE thread, but I'm a bit lost and would appreciate some help and/or advice.
I have a 16-64KB 5150 with a CGA card and a memory card that takes me up to 640K of RAM. I'm using a Zip drive for mass storage, but have decided I'd like to take a step up to a flash storage solution, probably most likely Compact Flash. But I'm a bit confused by what's available for purchase for those of us who don't/can't solder. So far as I can tell:
XT/IDE: Well-documented in wikis, but I've seen it described as obsolete, and I haven't seen any sources for assembled boards. I'm also not clear on whether this will work with an original 5150 (with a CF card instead of an IDE hard drive I'm guessing power wouldn't be an issue).
Lo-Tech XT/CF - Seemingly what I need, but obsolete.
Lo-Tech XT/CF v2 - Seemingly what I need, but still in testing to work some bugs out.
Lo-tech XT/CF Lite - Apparently some compromises from the V2, but I'm not sure how big a deal those compromises are. But this also still appears to be under development.
Is this a fair summary? For those of us that don't/can't solder, is there a semi-commercial source for an XT/CF board? At the risk of sounding crass, is there somebody I could pay for an assembled board as with similar flash storage solutions for other vintage computing hardware?
I feel like I'm close to getting this sorted out, but I'd *really* appreciate some help in figuring this out!
Thanks,
Chris Hafner
Thanks,
Chris Hafner
