Matlock
There have been a number of software updates to the SCSI2SD cards and some nice improvements to the hardware of the cards. The newest version that in a recent post (Sept. 24th) was mentioned as now being shipped from the U.S. with a price of $65. So I had to get a new one. The best thing is that it solves having to connect powder to the unit as it can draw what it needs from the SCSI bus. With the older units I had a separate supply giving it power (not a problem with BA23).
The new software is GUI based so it it easier to use and now the MicroSD card can be partitioned into 2-4 disk with different SCSI unit numbers. I've been using an Emulex UC07 on both the PDP-11/83 running RSX11M+ and the MINC-23 that I have been working on recently. To get the 11/23 to boot the DU I modified my BDV-11 with ROM images supplied by Malcolm which filled eight 2716B EPROMs (note program these 2716B chips with 12.5V not 21V which is used with the 2716) and everything was working great.
I have 256 KB of RAM and can boot either RT-11 V5.6 or RSX11M (not +) by changing the microSD card. Now I can start testing all the spares I have laying around. I check another 11/23 it's good, an 11/73 it's good, another 11/73 it's good, now I tried a different DLV-11J... I can talk to ODT but the UC07 won't boot... Hmm... I fire up F.R.D. on the UC07 and the UC07 seems good but it can't see the SCSI2SD... I try a different microSD.. FRD can't see the new card either (using the option 7) list drives command it just hangs. The LED on the SCSI2SD comes on and stays on but no drive. I switch back to the original DLV-11J, still doesn't work. I wonder if I fried something? I changed the settings in FRD all over the place trying to get it to see the drives but no good. I check the contents of the microSD card by using DD to load it on my iMac and boot Simh from the .dsk file image. No problem the microSD and its contents are good.
I try another SCSI2SD card and same result. Give up and sleep on it. It was working until I changed the DLV-11J, but that DLV-11 did work. I reseat all the cards, no dice, check the voltages, everything is good. Give up and sleep on it again, then talking through the symptoms with my son I realize, I haven't checked the cable. It was one I made my self so it could have a problem. After digging around in the cable parts bin, I find a factory SCSI cable that doesn't look like it has any unusual modifications and swap it out with the original. Works perfect!!!
I realized now that had I been a bit more systematic about diagnosing the problem, I could have figured it out faster.
Also having known working spares is invaluable. So I ordered another UC07 and when it came, just to see what would happen and swapped it out with the old one and did not configure it except to change one DIP switch setting and used one of the 11/73 CPUs that did not seem to use the new ROM on the BDV11. I did not fire up FRD to config anything on the UC07. It booted the RSX11M microSD straight up. Good to know that the factory FRD setting are fine for the SCSI2SD.
Anyway if you are having disk boot problems, in addition to making sure to LATFP "Look At The Front Panel" (as Ian pointed out a week ago), check the cable in the beginning of trouble shooting the problem, not last.
Mark
Mark
