UCSD p-System Amiga file transfer
spiceminer
Europe
Dear all!
I am currently having problems to transfer files from inside the p-System to the Amiga DOS and vice-versa.
There is a dedicated amiga.util.code which should do the job.
Unfortunately, I always get the error message attached.
I have tried with different Kickstart versions, on original hardware and emulated with the same result.
I suppose I have an error in the file.
The files on the p-System side reside in a "psystem.vol" virtual disk image in the AmigaDOS directory.
I assume this is the same for other p-System / Pecan Power System incarnations out there (IBM PC, Atari etc).
Is there maybe a tool which can be used to access the files inside the psystem.vol ?
I have searched the old Simtel archive but with no success.
Thanks a lot
Stephan
