Northern Europe [UK] EPROMs for sale, blank or programmed including MCM 68764C
Covers: Sweden, Denmark, Finland, Norway, Ireland, Lithuania, Latvia, Estonia and Iceland
1980s_john
UK
Hi,
Having just bought a batch of EPROMs and a suitable programmer I can offer the following for sale.
MCM 68764C, 8K EPROM, equivalent to 2364 ROM - £8 (blank), £10 programmed.
2708 1K EPROM, £3 blank, £6 programmed
2716 2K EPROM, £3 blank, £6 programmed
2532 4K EPROM, £3 blank, £6 programmed
2732/2764/27C64/27128/27C128/27256/27C256 £3 blank, £5 programmed
Please supply me with the exact file to be programmed.
Discounts for 2 or more the same.
Postage - UK - £1 for 1 or 2, please PM for EU/worldwide (but I would suggest you find someone local for the common chips).
Please PM if you would like me to program / read your EPROM.
Regards,
John
Hi,
I can supply and program a range of EPROM chips from 2708 to 27512, and also the MCM 68764. This can be used to replace most 2364 ROMs, where chip enable (CE) is negative (eg in the IBM PC).
MCM 68764C, 8K EPROM, £8 (blank), £10 programmed.
2732/2764/27C64/27128/27C128/27256/27C256/27512 £3 blank, £5 programmed
Postage - UK - £1.50 for 1 or 2, please PM for EU/worldwide (but I would suggest you find someone local for the common chips).
Please PM if you would like me to program / read your EPROM, I also have a UV eraser. My programmer also supports some EEPROM chips, please ask.
Regards,
John
Hi,
I can supply and program a range of EPROM chips from 2708 to 27010, and also the MCM 68764 / MCM 68766. Either of these can be used to replace Mostek MK36000 or MKB36000 ROMs and also most 2364 ROMs, where chip enable (CE) is negative (eg in the IBM PC, or some HP or Tektronix equipment).
MCM 68764C or 68766C, 8K EPROM, £9 (blank), £11 programmed.
2732/2764/27C64/27128/27C128/27256/27C256/27512 £3 blank, £6 programmed
27010/27C010 (200ns only) £1 blank, £4 programmed
Regards,
John
Hi,
Regards,
John
Hello @1980s_john
Are you still able to supply programmed MCM 68764C EPROMS?
Regards
John
Hi,
Regards,
John
Hi John,
I need Programmed rom chips for my IBM 5150 can you please provide me with these chips.
Thank You
Regards
Amin
Hi John,
I have been discussing trying to program a TMS2564 over [here] and modem7 suggested [this list] which brought me to you.
I then recognised your name from [here]. A Double match as I have a couple MW4s I am trying to resurrect.
I had assumed time had taken its toll on the EPROMs so was aiming to try burning new ones.
It has become more complex in 2 ways.
1. tried to write with GQ-4x4 to a blank 2564 but only first 2048 bytes written - so a next option is to find someone who can write successfully.
2. I read both of my MW4 2564s and got an exact matching .bin - so perhaps the EPROM is not the problem.
Can you help with the writing, and also - how have you got on with your Microwriters? I'd love to get mine running.
Thanks,
A
