jltursan
As promised, I've uploaded some photos of my recently fixed/upgraded Model 4P.
My 4P second drive has been broken since long time ago; so it was a great chance to not only fix it; but to completely replace the drive with a 3.5" one. First one the cable:
As simple as replacing one of the 5.25" connectors with a new 3.5" IDC type. Of course, one of the internal 5.25" type molex power plugs needed a replacement; but, instead, I used a 5.25" to 3.5" molex converter to do the trick.
Next, the 4P drive case and the 3.5" to 5.25" bay converter:
Yes, the 4P drive holder needed some work. I was forced to drill a new set of holes to screw in place the 3.5" converter and 360K 5.25" drive. Also, the converter and 3.5" drive were white; so they needed some black painting...
Here're the new drives assembled back in the main body:
To test the new drive, nothing better than boot with a TRSDOS dumped to a 3.5" floppy:
Meanwhile, surfing the web, I noticed how easy is to upgrade my 4P model to 128K; so with some 1x64K ICs (to be exact, 8 x MN4164P-15A) and a jumper the task was quickly finished. Below, CP/M 2.31 has finished loading from a 3.5" floppy and the 64K M: ramdrive appears empty in all its glory:
Sadly I don't know of any other software that takes profit from this upgraded memory; so that's all...
Now, I want to look for info about the date internals of the 4P+TRSDOS. The date, once inserted is lost inmediately when shutting down the machine; so I suposse that if there's a clock IC, it's battery must be empty. Also, TRSDOS doesn't accept any date over 1987; so as I've read about a patch, I'll try to fix it.
And the yellowing.....; yes, the computer is heavily yellowed; but maybe a bit of retr0bright will make some good for it some day...
Btw, I apologize for my broken english, take it kindly...:ashamed:
