stangman517
Greetings.
I have a Keyspan USB PCI Card recently installed in a Apple Mac G3 Beige desktop (clean install). I cannot get Mac OS9.2.2 to see the card.
The quickstart guide says: "If you are running Mac OS 9.2.2 you must install Apple's USB drivers from your Mac OS 9.x CD. To do this run the Mac OS Installer and proceed as if you are installing the OS. You will be told you already have the OS installed and asked if you want to 'Add or Remove' software. Click the 'Add or Remove' button. You will now see a list of items to install. Select only Mac OS 9.x from the list.. Under 'Installation Mode' select Customized Installation.' When you are asked to select which components to install, place a check mark next to 'Network and Connectivity.' Click the 'OK' button to return to the previous screen and start the installation.
Installation is now complete."
Ok I did this exactly and still the system does not see the USB card. Is there something else I need to do? Is it an extensions problem? Help is appreciated. I'm a neophyte Mac user, so be gentle. ;-)
Thanks
Thanks
