Tupin
Since I'll never be able to afford a BeBox barring some sort of windfall, I kind of want to get a BeOS system set up. I've read a bit into the manuals, apparently some versions just installed with Windows and others were main installs? I would want the second, as I want a dedicated BeOS system. Anyone around here have experience with it?
As for Haiku, if I am reading it right, is for semi-modern/modern machines, as it apparently can run on something as slow as 400MHz? What would be a good machine to install that on?
