That helps very much! Good to know what it finally is!I forgot...
Your's is not an VAX 4000 !
What you have is an MicroVAX 3100 model 98 !
Hardware should be the same (bc same chassis), i did not look after that, but imo the license costs are cheaper for a MicroVAX than for a VAX VMSwise...
Do you have permanent licenses installed on your system btw ?
Yes I have perm licenses installed, I've dd copied the hard drive to a new hard drive, and have been slowly cleaning that up, and been doing some reading over the years on how to backup the licenses, but everything is so very different on openvms.
This is what I've got, I did backup the .dat files, and the license issue output from a temp write of the disk.
------- Product ID -------- ---- Rating ----- -- Version --
Product Producer Units Avail Activ Version Release Termination
BASE-VMS-250136 DEC 60 0 A 0.0 (none) (none)
FORMS-RT DEC 200 F 0 0.0 (none) (none)
NET-APP-SUP-200 DEC 400 F 0 0.0 (none) (none)
OPENVMS-ALPHA-ADL DEC 400 0 100 0.0 (none) (none)
P.S.I. DEC 200 F 0 0.0 (none) (none)
VOLSHAD DEC 230 E 0 0.0 (none) (none)
The volume shadowing is offline as I only cloned one disk and am running it on a single disk (I dd copied over) so I don't derp up the main disk until I better understand things.
Some drives I have are from other Vax/DEC machines as well, but I can't seem to mount them, eg one from an AlphaServer 1000, which I don't think will be useful, but still neat to have a look around.
Disk VAXSTN$DKA300:, device type RZ29B, is online, file-oriented device,
shareable, error logging is enabled.
Error count 0 Operations completed 106
Owner process "" Owner UIC [SYSTEM]
Owner process ID 00000000 Dev Prot S:RWPL,O:RWPL,G:R,W
Reference count 0 Default buffer size 512
Total blocks 8380080 Sectors per track 113
Total cylinders 3708 Tracks per cylinder 20
I backed up the disk first, but tried mounting it with foreign and label USER01 (i think this was a whoops moment)
$ mount/noassist VAXSTN$DKA300 fx3
%MOUNT-F-INCVOLLABEL, incorrect volume label
-MOUNT-I-VOLIDENT, label = 'USER01 ', owner = ' ', format = 'DEC
FILE11B '
$ mount/foreign/nowrite dka300:
%MOUNT-I-MOUNTED, USER01 mounted on _VAXSTN$DKA300:
$ dir _VAXSTN$DKA300:
%DIRECT-E-OPENIN, error opening _VAXSTN$DKA300:[SYSMGR]*.*;* as input
-SYSTEM-F-DEVFOREIGN, device is mounted foreign
$ show devices
Device Device Error Volume Free Trans Mnt
Name Status Count Label Blocks Count Cnt
DSA0: Online 0
VAXSTN$DKA0: Mounted 0 OPENVMS071 712188 309 1
VAXSTN$DKA300: Online 0
Anyways great its back online! Hopefully I've done enough to backup the licenses, I understand those are important to save, and that's why im not running the original disk, but a cloned one for now. I do want to "clean up" the original disks though, so there are no previous remnants of its previous life (aside from installed Vax software and licenses) !
Jonathan
