VIC-20 16K Prototype
CommodoreZ
Z Labs
Howdy,
A few weeks ago at VCF East, I spoke with Robert "Bob" Russell, one of the VIC Commandos. I don't know what convinced him to do so, but he gave me a pair of later VIC-20 prototype boards.
First, the 16K VIC-20 Prototype. This machine is an internal prototype from Commodore of a VIC-20 variant that never made it to production. Some folks call it a VIC-16, but we have no official designation for it.
Back to the prototype, this seems to be the only survivor of the project. It was supposed to be sent out for FCC certification RF testing, but whether or not it made it that far is unknown. The machine does not include the top half of the case or keyboard, much less a serial number. It's based on the common 324003 production motherboard, with a few ICs rearranged to make room for 8x 6116 SRAMs in place of 8 of the existing 2114 SRAMs. If you pay close attention, you'll note that it has 17K of RAM, not 16K, plus the color RAM. When you start the machine, it reports 15871 bytes free. The power, 6522, CPU, regulator section, and VIC chip/RF cage otherwise look like a 324003. There are three stickers with notes on the system, and here's my best interpretation of what they say:
OK SMW 1-2-82
LATEST TEST
155 RESET
BAD 1/5/82 RAS
155
LARGE FUSE
BI BAD 6560
I'm not sure what the significance of 155 RESET is, but I have noticed this machine takes longer to display a READY prompt than most other VICs. Considering it does in fact run, whatever was wrong with the 6560 may have warranted a replacement. The ROMs on board were dumped and were confirmed to match production VIC-20 ROMs bit for bit. It has an MOS 6560E VIC chip, which is odd because the E suffix only seems to be present on PAL VICs. If you've seen an MOS6560E in something else, VIC or otherwise, I'd love to hear about it. The board is marked with a unique assembly number of 3016006.
The brown one is 324003 that has no solder mask or silkscreen, and was intended as an internal RAM test board at Commodore. Bob said that it was Jack Tramiel's idea to test the viability of Russian or Eastern Bloc 2114 SRAM, however this appears to have 10 Toshiba 2114s, and one unsocketed 2114 of indistinct marking.
I've taken to calling it the "brown board" because it has no solder mask or silk screen, and is just tinned copper on top of vaguely brown fiberglass PCB. Apart from the PCB, this board sports an early production heatsink for the 5V regulator, typically only seen on early Japanese VIC-1001s before they realized it burned users who reached in the cartridge port.
Bob says that Jack Tramiel wanted to test the viability of cheap Russian or Eastern Bloc 2114 SRAM. This machine was an internal engineering test bench to that end. However, the SRAM on board does not corroborate this claim. The 10 socketed 2114s appear to be made by Toshiba, and the remaining one is both soldered in place and has indistinct markings. It has no top half of the case or keyboard, but it does have a serial number of V1002001. It has a beautiful gold and purple ceramic MOS 6560 VIC chip, and some minor mods to the analog circuitry. The ROMs on board were dumped and matched to standard production VIC-20 ROMs. I've tried dialing in the color phase, but it's finicky -- otherwise the brown board works fine.
I've put all of my photographs and details I've discovered here:
https://www.commodorez.com/vic.html
The 16K machine was previously documented on Secret Weapons of Commodore - Super VIC.
iirc a 16k expanded VIC-20 takes a little bit more to boot than the unexpanded one.
BTW I don't know how some people can be so lucky to get such a beautiful piece of Commodore history, but let me tell you my envy just hit the 1000 points mark LOL
Measuring the startup time of a VIC-20 with a 16K expansion cartridge, I get closer to 4.5 seconds from power-on to prompt. It's been suggested by the VIC-20 Denial forums that the 155 markings on the 16K prototype actually mean 15S for 15 seconds of reset. That's not too far off, I measured the startup time at closer to 19 seconds in practice for that machine.
I've also taken some better photos of the mystery soldered 2114 SRAM chip, and I think I've identified it as MOS-manufactured:
Under the right lighting (and highlighted with a bit of high contrast applied), you can see the MOS logo faintly at the top, followed by MPS 2114, and 30L 2280, which seems consistent with PET's sporting MOS 2114's of the era.
The last bit of update is from the 16K VIC prototype. I ran some memory PEEKs to see the layout of the address space a bit better. I've included the short program for transparency purposes, but if there's some other tests or PEEKs that folks would like to see, I'm all ears.
that's interesting. Why did they set such a long time for reset? It's seems a loooong time to me....
BTW 15 secs + about 4 seconds for the 16k boot gives you 19 secs, that seems correct.
Would be interesting to see if it boots with a lower reset time, but it would also be a pity to make experiments, changing caps and resistor in such a beautiful prototype ....
thats a nice looking board. I would mount it on the wall with a small placard.
Wasn't this machine supposed to be the VIC-30??? :o) Tony K., Commodore Collector/Restorer... ;)
Wasn't this machine supposed to be the VIC-30??? :eek:) Tony K., Commodore Collector/Restorer... ;)
I've discussed the possibility at length with folks like Robin from 8-bit Show and Tell. Without the hard piece of evidence (the improved VIC chip variant), or any special ROM, the answer is a very dubious "maybe?"
Here is the VIC chip lineage:
6560 VIC-20 (NTSC)
6561 VIC-20 (PAL)
6562 was supposedly for the TOI (the competing VIC-20 prototype design that looked like an apple II)
6563 (might have been TOI, might have been first-gen 40 column color chip)
6564 (what was supposed to go in the Color PET that never materialized)
6566 VIC-II (no DRAM refresh circuitry, for the MAX machine)
6567 VIC-II for C64 (NTSC)
6569 VIC-II for C64 (PAL)
Without one of those unreleased VIC chips, this is just an integrally expanded VIC-20 with no backwards compatibility for software that requires an un-expanded machine.
