PS It has a driver disk, should I try that?
So I gather that the card reseat (remove card then reinsert card) didn't fix the problem.
The error beeps indicate a basic problem during startup, one which no driver disk will fix.
By "
It worked before shipping", I presume that is what the seller indicated. If so, then of course there is the possibility that the seller was lying. Maybe the seller was ignorant and thought the moving text was normal.
What you expect to observe on a 5150 is:
1. Power on
2. Power on + about 10 seconds: Cursor appears on monitor (unlike the later 5160, no RAM count-up is shown)
3. Power on + about 50 seconds: Floppy drive LED turns on (POST checking drive)
4. Power on + about 51 seconds: Single beep from speaker (indicating POST complete)
5. Power on + about 52 seconds: Attempts boot from floppy drive (start of boot sequence)
One thing to check is the DIP switches on the motherboard. On switch block 1 (SW1 - the one closest to the expansion slots), what are the settings of switches 5 and 6 ? What type of monitor/card do you have - MDA, CGA, EGA or VGA ?
