kingchops
A contact of mine has a VT100 terminal with a working motherboard, PSU and keyboard but no CRT and video driver board. I'm thinking of buying it and installing a small flat panel inside the case. I could then use the video composite out on the motherboard to feed the display. I'm also thinking of installing a Raspberry Pi in it as a project and running a DEC emulator.
This would be quite easy to do, but the problem is finding a suitably sized 4:3 lcd display. The CRT on the VT100 is around 12". Does anyone know of a source of suitably sized lcd monitors/composite tv's that could be used for this?
Over the weekend I plugged my working VT100 into an external composite monitor to see how well it works and it works really well.
