lsi11al
Now that I have my 11/23+ system running I wanted to try using a real DEC terminal. Connected a VT320 to the computer and all the boot up information appeared on the screen. However, when I went to respond the terminal is apparently not sending to the computer. I have the cable from the terminal plugged into a H8575-A adapter which is then connected to the Dbit cable going to the RS-232 port on the CPU board. I tried connecting pin 2 to 3 on the H8975 but got nothing on the screen. I ran through the loopback tests suggested for the terminal and end up with the VT320 DEC-423 Port Error -- 5. Also tried the printer port and got Error 6. So apparently I only have one way communication - computer to terminal. Anyone have further test suggestions or a possible fix? Or am I just out of luck with this particular terminal?
Thank you for any ideas.
Al
Al
