Ok so I have upgraded to 130W and things are working well. Now I wanted to see if I could get that 2nd hard disk (another ST-251) going. I am pretty certain I have all the cabling correct... a summary:
I have a single floppy disk with the 5150 configured for 1 floppy drive. This is connected the stock FDD controller.
WD1002A cables:
Control Cable J1: Drive C - middle position, Drive D - end position
Data Cable J2 (Drive 0): Drive C
Data Cable J3 (Drive 1): Drive D
ST-251 Drive C: Jumpered to DS2 (No resistor pack)
ST-251 Drive D: Jumpered to DS3 (Resistor pack installed)
No other jumpers installed on ST-251's or WD1002A.
I enter the low level formatter (Debug, g=c800:5) and it says "Current Drive is C:, Select new Drive or RETURN for current."
I try entering D: but it says "Invalid device". Tried difference options too, like "D", "2", "1".. if I enter "C" it takes it but obviously that's not what I want.. C is the boot device and I need to format D.
When entering FDISK I don't get the option to switch fixed disks, so the DOS is not seeing that I have a 2nd fixed disk installed. Any thoughts?
I was curious about the drive select on the ST-251's.. Should they be DS1 & DS2? Because when I tried that it wouldn't boot to my C... took me into BASIC.
