I have this computer 8088 - 8MHZ
DTK look a like PIM TURBO 640 Motherboard
Motherboard have a full 640Kb of system memory.
Clone IBM XT case. (No LEDs or TB switch) (but there on the motherboard (header)
Seagate ST-296N 84MB Partitioned:
C: 42MB
D: 39MB
With FDISK on MS_DOS 4.01 bootdisk
Seagate ST-02 SCSI controller (without floppy disk support)
Joincom HD floppy controller
360KB Chinon 5.25 inch drive
1.44MB Mitsumi drive.
Video7 VEGA 8BIT graphics adaptor.
Trying to install MS-DOS 4.01 on 720KB 3.5 inch diskettes (dutch language)
Had some trouble to get it booting. But i have fixed that already.
When the diskette boots it comes in the SELECT screen.
I want to install it from SELECT to the HDD on C: drive.
I have two things that will happen.
1. It goes to the Welkom screen. Hit ENTER and that goes to the INTRODUCTION screen.. And from there i cant go any further.. The system might be locked up. (booted with the original diskette)
2. And some times i cant get any further than the WELKOM screen..
System locks again and dont getting any further.
What can cause this problem? If i starting the game Testdrive 1 and Grandprix, the gamess are just running fine..
I cant see if the system turbo mode is on or off.. I also dont feel it on the system performance. Its neither slow or fast for my feeling.
I have made already a new floppy disk installation set. It hangs on the same spot. So it wouldnt MS-DOS diskettes related.
C: 42MB
D: 39MB
