Received an Acorn Archimedes 410/1 on Monday. It has all the ram banks filled(4megs), Risc OS 3.x ROMs, a MJE Micro ARM3 Booster CPU as well as an IDE podule along with a 170meg IDE hdd. These had an ST506 hdd interface built in to the mobo , use a DD 3.5" fdd and shipped with Risc OS 2.0. The wasn't fitted to the 410/1 as standard though from what I can gather. Early models have a Synch on Green issue when hooked up to vga monitors. The machine fires up, but I need to a aquire an RGB to VGA adapter to see whats going on via a monitor as I don't have a suitable RGB monitor. No fdd activity but the fitted hdd made all the correct noises. Best of all there was no POPS! or BANGS!
I'm in the process of cleaning around the battery holder and going over the mobo. The plan is to get a network podule for it and fit a bigger hard drive to fit all the stuff from the Qube site I linked to above. The IDE podule has the option of either a 40 pin (one internal as well as an external IDE connector) or 44 pin IDE drive which is handy.
Edit- Managed to get a speaker tone, so a step in the right direction.
