jeff0172
ok thank you i ordered the cables all i need to get now are the disks.No, you will want DSDD (720kb/800kb), not the newer DSHD(1.44mb) or DSED(2.88mb).
Something like this should work.
ok guys i have made the boot disk! nowthe system runs like a champ ya the problem with the old one was that it was damaged now i have a haveing a problem with the disk drive i put in the disk and the floppy disk does not go in all the way i have to push it in with a paper clip is there any way of fixing this? does the drive need to be cleaned? it reads disk and ejects them fine
ok thank you is white lithium grease ok?
I would think so, so long as there's no rubber parts (which I don't think there are), I want to say lithium grease can degrade rubber parts, which is why I would usually prefer silicon grease.
The key, and the reason its probably sticking, is to get the OLD crusty grease out of the mechanism. I would say most the time the old dried up grease is why its sticking in the first place.
