A better picture will make it more obvious. Wang did sell a lot of network cards with paired connectors similar to that card. Doesn't mean I am sure that it is, the images aren't detailed enough to confirm.
You will see some details about the dual coax arrangement that linked workstations to the CPU
This is no doubt a PC card that would enable terminal emulation then to a Wang system. As per previous posting, please post some high resolution images.
I never kept our 2200 but it was impressive at the time.
http://books.google.co.nz/books?id=...0CEAQ6AEwAA#v=onepage&q=Wang PC Local&f=false
Good reading.
Working out their stuff now is difficult because most offices probably tossed their gear - but whenever I do research I actually see what a clean system is described and usually well featured.
There was also a verison for the original Wang PC which had a switch that would let it boot from the network ("Remote / Local"). All uses that twin BNC connector system.
