Yes, on those early Pentiums, you just set your multiplier and bus speed, and the chip would try to run at that speed. It was very common for people to buy Pentium 75s and then see how fast they would run. In the later days, a lot of people reported getting P75s to run as P133s without issue. I tried overclocking P75s twice and both times they acted goofy, even if I only went to 90 MHz. But a lot of P75s, especially the early ones, were just P90s that couldn't run reliably at 90 MHz.
It was common practice back then to mess with bus speeds and multipliers. Once boards with a 75 MHz bus arrived (to support Cyrix chips that ran at 75 MHz x 2), people started trying to run Pentiums at 75 MHz x 2 and found they ran faster than P166s did. Then people discovered an undocumented 83 MHz bus on a couple of boards, and found a P166 running at 83 x 2 was faster than a regular P200. And a Pentium running at 208 MHz, 83 x 2.5, was the bomb.
The trouble was that when you did this with an Intel chipset, you ended up with the PCI bus running at odd speeds, so the systems weren't always stable. It was easier to get away with a 37.5 MHz PCI bus than a 41.5 MHz one. And that was on top of overclocking.
That had a lot to do with why Intel started locking the multipliers with the P2 generation. People would buy P120s and P133s and then clock them as high as they could get them to run. I remember going to Tom's Hardware the first time, and right there on the front page was a series of articles telling how to overclock Pentiums on Asus motherboards. And most of the ads on the site were advertising bundle pricing on low-end Intel CPUs and those same Asus motherboards. That was how most of the long-running hardware enthusiast sites got started.
