Marty
Hi All;
Does anyOne know What Voltage Bulb was used on the Front Panel for the PDP 11/45 ??? My guess is somewhere around 8 volts to 14 volts.. I am assuming that it originally used Bulbs, but it could have been Leds, since the PDP 11/40 was Led's..
I am Thinking for Now that IF possible I will use Led's. Since I have Plenty.. And with the Pull-up resistor that the Front Panel uses will help determine what voltage I need for the Leds.. But, knowing what voltage was originally used would help me (I think)..
THANK YOU Marty
THANK YOU Marty
