Where can I find the COmpaq LTE Elite 4/40c processor pinout?
rmay635703
Wisconsin
I don't have multiple CPU cards to check anymore but the compaq elite LTE series of 486 laptops had an upgradable surface mount 486 chip on a cpu card that plugged into a pair of edge connectors.
The bus speed and voltage set by pins on the processor card being grounded or hung to a voltage.
I believe I can modify a card to accept a 5x86 surface mount or even overclock my dx4-75mhz cpu I dropped in years ago but without the pinout I can't accomplish this (not sure how to follow through the circuitry)
I do know 3rd party AMD 5x86 150mhz cpus where offered for these old beasties so apparently the lappy could support 50mhz FSB. Too bad I can't figure out how or what pins to ground on the edge connector.
I have a similar question on the Compaq LTE Pentium 133 and 150mhz laptops both have identical motherboards so there should be a way of setting the FSB, even though the mobo doesn't have apparent settings.
Thanx for any help
Ryan
