Width of 1084 monitor and PCjr
NsMn
Germany
Hello,
I'm not quite sure if this is the right board, I'm new here, after all.
Basically, what I wanted to ask for are the widths of two pieces of hardware, to plan out my desk. These two are:
- Commodore 1084 monitor (It's the first version I believe)
- IBM PCjr with one sidecard
I hope you can help me, and, of course, to become part of this community (...that sounded shmaltzy).
carlsson
Västerås, Sweden
I have two different 1084 monitors on my desk. One is the model that has SCART and a 6-pin DIN TTL input next to the RCA inputs. The front is 34,5 cm wide. While this one might not be the very first 1084, I think it represents the early model quite well. The second monitor has DB9 input which is switchable between TTL and analogue. It also has stereo sound, is newer and thus wider, a whole whopping 36 cm on the front. Convert to inches if you feel required.
Of course you will need a couple of cm of space next to the monitors as well. I would say allocate 40 cm for each 1084 monitor, if your measurements need to be that exact and planned out ahead of time.
NsMn
Germany
That sounds good, thank you so far.
Especially for pointing out the needed space between the display and something else.
...so... only the PCjr missing.
