Need help with Sound on Windows NT 3.51, I solved the rest of the issues with HW v6
Has anyone successfully booted Windows NT 3.51 on VMware Player? It installs just fine, but I can't get it to boot.
I installed Windows NT 3.51 with SMP on Fusion 6.0.2.
I need help ONLY with sound, EVERYTHING else works.
Here is my VMX (below)
High res video for NT 3.51:
The way to make your video work is to put FRAMEBUF.DL_ (from CD:\I386) - expand c:\winnt35\framebuf.dll and c:\winnt35\system32\framebuf.dll. Then use this driver for high res:
http://bearwindows.boot-land.net/vbempj.zip
I need help with sound:
Need help with sound driver. If anyone can give my any working sound on any vmware product with NT 3.51 let me know what the VMX looks like pretty please.
I got everything working in NT 3.51:
I got SMP working with VMware HW Version 6. SMP works, 1024mb ram, 4gb C-drive, networking works, 1280x1024x32bit VESA working, everything is working but SOUND! How do I get sound working in NT 3.51. I tried es1371 and sb16, I need help.
.encoding = "UTF-8"
cleanShutdown = "TRUE"
config.version = "8"
displayName = "NT351S"
ehci.pciSlotNumber = "19"
ehci.present = "TRUE"
ethernet0.addressType = "generated"
ethernet0.connectionType = "nat"
ethernet0.generatedAddressOffset = "0"
ethernet0.linkStatePropagation.enable = "TRUE"
ethernet0.pciSlotNumber = "17"
ethernet0.present = "TRUE"
ethernet0.wakeOnPcktRcv = "FALSE"
extendedConfigFile = "NT351S.vmxf"
floppy0.clientDevice = "FALSE"
floppy0.fileType = "file"
floppy0.present = "TRUE"
floppy0.startConnected = "FALSE"
guestOS = "winnt"
hgfs.linkRootShare = "TRUE"
hgfs.mapRootShare = "TRUE"
isolation.tools.hgfs.disable = "FALSE"
memsize = "1024"
mks.enable3d = "FALSE"
numvcpus = "2"
nvram = "NT351S.nvram"
powerType.powerOff = "soft"
powerType.powerOn = "soft"
powerType.reset = "soft"
powerType.suspend = "soft"
replay.filename = ""
replay.supported = "FALSE"
scsi0.pciSlotNumber = "16"
scsi0.present = "TRUE"
scsi0:0.fileName = "Virtual Disk.vmdk"
scsi0:0.present = "TRUE"
scsi0:0.redo = ""
scsi0:1.autodetect = "TRUE"
scsi0:1.deviceType = "cdrom-image"
scsi0:1.present = "TRUE"
scsi0:1.startConnected = "FALSE"
softPowerOff = "FALSE"
tools.syncTime = "TRUE"
tools.upgrade.policy = "upgradeAtPowerCycle"
usb.present = "TRUE"
usb:1.speed = "2"
virtualHW.productCompatibility = "hosted"
virtualHW.version = "6"
vmotion.checkpointFBSize = "16777216"
sound.present = "TRUE"
sound.fileName = "-1"
sound.autodetect = "TRUE"
hpet0.present = "FALSE"
ide1:0.present = "FALSE"
pciBridge0.present = "FALSE"
pciBridge4.present = "FALSE"
pciBridge5.present = "FALSE"
pciBridge6.present = "FALSE"
pciBridge7.present = "FALSE"
serial0.present = "FALSE"
vmci0.present = "FALSE"
sound.pciSlotNumber = "18"
monitor.phys_bits_used = "36"
checkpoint.vmState = ""
