I'm wondering if we could easily make one.
Jim Brain has been helping us out with CC-40 peripherals lately. The 74 has the cassette stuff mostly built in.
Some folks on Stack exchange got a rudimentary interface going:
https://electronics.stackexchange.c...g-to-cassette-with-80s-basic-calculator-ti-74
Here's what the innards of the cassette interface looks like:
http://www.datamath.org/Graphing/JPEG_CI-7.htm#PCB
YouTube video of what the cassette signal sounded like:
https://www.youtube.com/watch?v=q_TumkmldJk&feature=youtu.be
Note that the interface is just a 74HC367 (3 state hex line buffer/line driver), a CA358E (Op Amp), and a bunch of caps, resistors, and transistors.
"Paolo" on the Stack Exchange discussion was on the right track for a home-brew adapter:
------ clip ------
I realized such an Interface severals years ago. The "Data Output" pin is pin #6 --> D3. The "Data Input" pin is pin#3 --> D0.
Recording:
you are on the right way: just use a voltage divider (e.g. 2 resisitors) to match the voltage requirements your recorder. A 100nF capacitor between voltage divider and mic-input could help.
Playback:
You have to clean and amplify the recorded signal, it must be a square wave, with low state = "GND" and high state = "VCC".
I used a common LM358N as non inverting Schmitt-Trigger to obtain a clean wave. It'easy, you need only 4 resistors. I played wit several resistor values, I obtained the best results with a 0,3V treshold.
You can supply the LM358N from Pin#1. Ok, it drains power, but not noticeably ;-)
I used the same interface with a Sharp PC-1260: VCC: pin#2, GND; pin#3, data in: pin#6, data out: pin#7
Have fun!
Paolo
------ clip ------
