Wtb: Ibm gpib isa
the3dfxdude
US
Does anyone have an IBM GPIB 8-bit ISA board, otherwise known as a National Instruments 6323705 or compatible? I would like to make sure it has the same jumper blocks and compatible NEC D7210C. This is because I want to use software written for it, and I am unsure how standardized the controller is. According to the software, the jumper configuration is important. There is alot of test equipment using ieee-488, and randomly picking up a controller is not what I want to do. Programming information also would be helpful. I already know the jumpers. Also, if someone has a cable, that would be nice, but I'm not worried about finding one of those.
I do not have the board you are looking for.
I have a National Instruments AT-GPIB/TNT (PLUG AND PLAY) with a label saying 183663C-01
If you are interested in this, please shoot me a PM.
smp
Hi. Thanks to the both of you. The AT version does not have the same DMA jumpers as the PC/XT version, and I need DMA 1 and only have 8-bit slots. I will be sticking with the PC/XT version for now.
The IBM GPIB (8-bit) looks alot like a National Instruments "GPIB-PC" board from the same era. (NI made the IBM board). The only thing different is there is a blue switch block in the NI version, whereas the IBM board had jumpers to set the "adapter selection". I think this set the I/O address (up to 7 addresses). And there is a thing called "Interrupt Acknowledge Level" In the IBM databook, that I don't know how that works. If I can figure out where it corresponds then maybe that one will work. It seems more common to find.
