WTB: ISA IDE hard drive controller card
oblivion
Apache Junction, AZ
looking to buy a 16 bit ISA hard drive controller card with its own BIOS. the PC i'm working on has a pretty limited BIOS and seems to be incompatible with a lot of later IDE drives I've tried so I need a card with its own BIOS.
SCSI isn't an option ATM so I need an IDE controller.
If you have a regular 16 bit ISA hard drive controller, then you could just add a simple ISA option ROM board. Then you can use a Universal XT-IDE ROM BIOS. You could even do this using a 16 bit NIC card.
I have a Silicon Valley ADP-60 board that you can have for the cost of shipping.
Before you give up on your prior idea though, and sacrifice a slot, you might try a 340MB MicroDrive in lieu of an actual CompactFlash card. I have a system in a similar situation as yours that refuses to work with 256MB and 512MB CompactFlash cards, but works fine with the MicroDrive.
after looking through my stuff I actually own no ISA HDD controllers but thanks for the idea Lucas
Cloaudschatze, I'll take you up on that offer, sending PM. I'm not to worried about using up a slot, Its going to be limited to a few specific games and uses anyways. how does speed with those micro drives compare to a standard HDD anyways? I assume its about on par with a standard modern IDE drive?
are you sure it works with hard drives? I have a similar card with 2 rca connectiors and it only works with CD drives
Hi
The XT-IDE V2 will do that with 16 bit IDE and built in BIOS.
http://marketplace.vintage-computer...embled-and-verified-working&auction_id=115004
Thanks and have a nice day!
Andrew Lynch
I'd love a xt-ide but if i had the extra cash to shell out for one it would be going in a old Tandy, XT or 8088 PC
Hi, are either of these what your after? One is an "Standard Microsystems SMC 4003-PC 8-Bit Disk Controller Board" the other is an " Lonshine Microsystems LCS-6210C 8-Bit Disk Controller Board"
Cheers
Sy
What machine is this for? Do you know if it implements full PC/AT 16-bit ISA (i.e., with ISA B8 line being ZWS)?
Thanks, my question was for the OP though (since they had asked for a 16-bit adapter).
Oblivion: If your are still looking for a 16-bit IDE controller you might be interested in this one: http://www.amazon.com/dp/B00004Z6H9...e=asn&creative=395133&creativeASIN=B00004Z6H9
I have this controller in one of 486 boxes and it works pretty good.
