Covers: North Dakota, South Dakota, Nebraska, Kansas, Minesota, Iowa, Missouri, Wisconsin, Illinois, Michigan, Indiana and Ohio
So, I've got myself a server build going with a MS440GX board at the heart! Issue is, the SuperMicro SC850 chassis I've got seems to be missing some important parts. This board in particular is pretty important., as it controls the fans for the entire machine. It may be what the power, reset, and alarm off buttons are mounted on, too. Anyone have a lead on one? It was used on several of their Slot 2 and Socket 370-era machines, including the SUPER SERVER 8050. The part may be common with other chassis that reuse the same basic design, including the SuperChassis 830. Unfortunately, I am unable to find any documentation which has part numbers for the board.
Would it be this from
here
Not a Supermicro chassis I have seen before, but a part no. might help find one.
Front Panel | CSE-PT4 | - | Front Panel Control Board for SC850 |
here
Looks like that'd be the right P/N! That's a big step in the right direction. Thanks!
It looks like the status LEDs and power switches are mounted on a separate board, which I haven't found much else on yet. The case must have been partially parted out before I got it? I'm considering just pulling the triple PSU/chassis controller assembly and trying to hack in a single ATX supply, replacing the missing switches with off-the-shelf parts.
