Hi,
i recently got a Tandy 1000 SL case, but it came without the rails for the bottom drive. Unfortunately Tandy made it so that the bottom drive needs some sort of plastic rails to be first attached to the drive sides before sliding the drive into the frame. The upper drive doesn't need any sort of rails because its made so that any standard 5.25 drive or bay fits, but Tandy made it intentionally the metal frame wider on the bottom so you would need the rails.
If anyone has some spare rails i would like to get them.
Thank you
Thank you
