Hi there,
I came across this thread and I hope that I can help.
Nick_Zravre - I have two 1400LT's:
One works fine and is in good shape cosmetically - the 'B' floppy drive does not work and the case is a bit yellowed, but it has the original, working power adapter, the optional modem card, a Tandy DOS/GWBasic disk and the Tandy 1400LT quick reference guide. It boots, runs, and the screen is bright and clear. If I end up keeping it, I will Retr0brite the case and rebuild the floppy drive.
I have a second that is in good shape, other than the screen. I have removed the LCD screen (it was cracked as a result of poor shipping), but the analog video shows that the computer boots and works fine other than the display. The 'A" drive sounds a bit scratchy, but works and the 'B' drive is fine.
Commodorejohn - I have two 1400HD's that I am trying to build into one good one and I am not sure that I have enough good pieces between them, but I do have at least one good hard drive (I can't get the other computer far enough along for it to spin up). Is it possible that you would consider letting me have yours and I could pass either one or both of my 1400LT's to Nick_Zravre?
Both of you let me know what you think...
