TMA-1
Hello all,
I've been lurking on this forum for awhile, and have learned a lot. Having a rather mysterious problem though. I searched, but only found one similar post, and no answer that fit my situation.
I have an Eagle PC Spirit luggable clone. It is an 8088 with no CMOS BIOS setup. It originally came with two floppies, but I later substituted a hard drive in the 2nd of two bays. I have never this problem before, but now it seems to want to boot to the hard drive instead of the floppy first.
Once it boots from the hard drive, the floppy is available and works fine.
I've tried two different floppy controllers. Neither seems to take priority from the hard drive.
Both the "straight" connector and the "twisted end" connector of the floppy ribbon produce the same results.
If I remove the hard drive controller, the system boots from the floppy as it should. Put the hard drive back, and it takes priority over the floppy.
I don't remember changing anything since last time I had this machine "out to play", nor do I know of any jumper setting (main board, floppy controller, HD controller, drives) that could alter what I always thought was carved in stone. Floppy first, then hard drive.
Which aging component has gotten senile, the computer or the user?
Ian
Ian
