ibmapc
Count me in!! I'd buy one or two for sure.
VCF Southwest | June, 2025 | University of Texas at Dallas |
VCF Southeast | June, 2025 | Atlanta, GA |
Hi
The board has two connectors for a pair of internal floppy drives on each for a total of four internal floppy drives. One of the internal connectors is also common with an external connector so if you use it then you would have two internal floppy drives and two external floppy drives. No special cables necessary. Hopefully that makes sense.
Thanks and have a nice day!
Andrew Lynch
Shouldn't amount to a hill of beans on programming. Both, incidentally support 2.88M drives (how long has it been since anyone's seen any DSED floppies for sale?). I wouldn't let the analog components bother you--stick with 5% parts and I think you'll be fine--after all, they don't determine timing; they just form a low-pass filter so that PLL doesn't lock onto extraneous noise.
Cheers,
Chuck
A few minutes ago, at eBay item 220342277766how long has it been since anyone's seen any DSED floppies for sale?
@Andrew I am willing to be a tester, I just need a Gerber file I have access to a proto milling machine.
Oh, And go easy on the Via's.![]()
@Lucasdaytona They are not pin compatible.
