atari2600a
As some of you know ("remember" would be a better term for it), I snatched an RGB monitor circa-1987 during neighborhood cleanup. (along with a TRS-80 Model 4)
Today, I managed to salvage what I could of the short stub of the cut cable, & there are the following wires:
-Red (Red)
-Blue (Blue)
-Grey (Green)
-White (I'm assuming Composite Sync?)
-Brown (?)
-Yellow (?)
-Black (Apperantly ground; leads to the same trace as the RGB & cable grounds)
I got RGB & Csync hooked up to my Neo-Geo MVS cabinet, but the image is all blown up.
I've tried putting the Sync output to the Brown & Yellow leads, which did nothing if memory recalls... (as in I'm not too sure)
Does anyone know what the other 2 leads are?
-Red (Red)
-Blue (Blue)
-Grey (Green)
-Brown (?)
-Yellow (?)
