Hi all
I've got a 1541C here. While I am familiar with the older models I have trouble finding the schematics for this one. My board revision is 251854 REV A, it's the one that is half-size the drive and has a hybrid IC. The heads measure ok therefore I want to try to repair the board.
The symptoms are exactly as described here:
When I switch it on it sounds normal, but when its reset by switching on the C64 it spins longer than usual. Trying to load from it results in everything not responding anymore.
The 7406 next to the serial connectors appears to be ok, I'm thankful for any advice in narrowing it down where else to look.
