I was bringing up my old T250... power supply came up fine (no RIFA caps), 8" drives came up fine (well, I did have to disassemble the spindle bearing and grease it), motherboard works... but the monitor failed after a few minutes.
I pulled all the semiconductors and tested them - they seem fine. The caps test ok (but I will replace them anyway). Found two tantalum caps that didn't short (!). One of the two fusible resistors on the CRT driver does appear... suspicious. It obviously got hot, and the value is unreadable. The other one is 0.5 ohm.
Does anyone have a lead on a service manual for a Toshiba monitor? The flyback used is a DH-1183 (T-WGS14) and the board is labelled "PB-811B". Suggestions appreciated.
I am creating a schematic if this helps anyone else.
