It looks to only have one pin in the connector. I'd say it wasn't a jumper but a location to connect a test cable. Since it is on the motor control board, I would suspect it is used to look at the motor speed. It maybe looks at the control voltage range or something. The connector on it is to keep one from accidentally bumping and shorting the pins. It is not a shorting jumper.
Dwight
