VirusVox
Hey all!
I'm not sure if this is a hardware issue, or a memory management issue on my end (I've never set up RAM in MS-DOS 6.22), but today I installed 4 1MB SIMMS in my 386, which should bring the total RAM to 6MB. The RAM was purchased as tested and working, so if the listing is trustworthy and accurate I'm not sure what's happening here. When loading the computer sometimes it will detect 640K of conventional memory, and 2048K of Extended Memory. But for the most part it detects 640K Conventional, and then beeps a few times in a high pitched tone. After that I get 3 short beeps and DOS force-loads into DOS Low.
In my CONFIG.SYS I have it set to load in this order:
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE
DOS=HIGH,UMB
FILES=30
Am I making a simple memory management mistake, or is this more than likely something deeper, hardware related? There were no SIMMS installed when I got the PC, but I can tell there definitely have been in the past as a couple of the tabs on the SIMM slots are broken off. All SIMM slots still have at least one tab so the RAM is still seating correctly from what I can tell.
I also have the RAM installed in the two slots farthest away from the CPU, one empty slot, and then the next two slots. I was troubleshooting that specific empty slot as it seemed as soon as I put a stick in it, it forced it to load into DOS Low, but that could've just been coincidence as it's still doing it.
Any ideas?
Thanks!
DOS=HIGH,UMB
FILES=30
Any ideas?
Thanks!
