dongfeng
I've finally managed to get this awful motherboard sussed out and set up now, I don't think I have ever seen such a complicated design for setting things up! About 1000 different jumpers!
Anyway, a couple of questions
1. Turbo Button. My turbo button has 3 wires, but the motherboard only has two pins. It is set up on 2 pins and works - LED comes on when Turbo is engaged, and off when disabled. Benchmarks show the hardware is responding too. There is also a neat display on the case showing the speed (75MHz). Years ago, when I had it with a 33MHz, the display used to change to show the lower speed when turbo was disabled. How can I do this? At the moment there are no wires either from the button, LED or mainboard to the display board (only power), but I would assume there should be to detect the speed change.
2. This is the mainboard schematic:
http://www.thegreenhouse.us/th99/m/I-L/33140.php
J1 and JP13 are labelled as "Green PC Connector". What is a Green PC Connector?
Umm... that's all for now! Thanks in advance
