NF6X
I'm working on a model 4P that I just acquired from eBay. If you've seen my recent disjointed ramblings elsewhere, then you may recall that I have no bootable floppies for it yet, and rather than taking the easy (practical, sane...) way out, I'm planning to try to hack together a scheme for writing downloaded floppy images onto real disks on the 4P, using its RS-232 boot mode to download some sort of disk writing program that I'll need to develop. Similar schemes exist for the Color Computer and Apple II, using the Wired/DriveWire and ADTpro tools, respectively.
I'm digging around inside the 4P to take care of preliminary tasks like washing mouse pee out of the case, cleaning up drive heads and card edge contacts, and so forth. I found that drive 0 is no good. Its spindle bearing is shot, and the drive belt is nowhere to be found. I got the bright idea of replacing the original pair of drives with a pair of nice Teac FD-55B drives that I just got, originally planning to use them with one of my Color Computers. They look like they're either unused or refurbished, since they're very clean and they came in what looked like OEM packaging. The detail that makes me think they might be refurbished is that their serial numbers are very close together, yet they have different spindle motor assemblies in them. Same markings on the drive motor PCBs, but different PCB and motor designs. Weird... I wonder if they slapped in motors from different alternate suppliers on a single production run?
Anyway, I had them all bolted in to the drive mounting frame, and then I discovered that they don't fit in the case because their faceplates stick out about 1/8" farther than the faceplates on the original Tandon drives. Nice.
So, what do y'all think I should do next? Punch new holes in the drive mounting frame so that those nice Teac drives will fit in the case? That gives me beltless double-sided drives in the 4P, but it'll make purists and preservationists cringe due to the new mounting holes and different front-panel appearance. I'm not sure how much that bothers me, but it clearly bothers me a little bit since I'm here asking for input. Or shall I fix the bad Tandon drive? The spindle bearing may not be a problem if it's a standard size of ball bearing, but I gather that belts for these things can be hard to find nowadays. Or maybe I should look for another good used Tandon drive to replace it?
For now I just swapped the two drives so that drive 0 is the hopefully-good one.
Even though it's a bit frustrating when things don't work or don't fit, I'm having lots of fun playing with this old stuff!
