neutrino78x
in case anyone hadn't seen it:
5.25 inch floppy interface to USB.
where you can order it.
So, basically, you would get a 5.25 inch drive, hook it up to this device, hook it up to power (120 VAC to 5 VDC adapter) and rock n roll.
I need to get one of these, because my 5150 PC is still in storage, and I have that public domain program Menu Maker, published with the book Fully Powered IBM PC (from the editors of PC World), that I want to post on the net.
Menu Maker was an awesome program that allowed you to make a color text display and save it in BASIC BSAVE format, to be later displayed by a BASIC program. The intended use was if you had macros and batch files set up in DOS, such that you could press, for example, Alt-L to bring up Lotus 1-2-3, and you wanted to display a menu for that setup.
The PC World editors figure that if you use a macro processor like ProKey, and then Menu Maker to make menus, you could have basic, DOS, prokey, and the menus stored in a RAM disk in a dual floppy PC, and you could display the menus instantly. BASIC BLOAD displays the file instantly because it writes it directly to display memory.
Of course, you could always use ANSI.SYS instead of prokey for macos (at least at the DOS level) or you could make your batch files consist of 1.bat, 2.bat etc. ;-)
I wish somebody better at programming than me would take the source code to Menu Maker and make an enhanced version that can write the menu as a text file with ANSI color commands, since with a modern computer, typing "type file.txt" is pretty close to instant.
I don't know if the UNIX console has the equivilent of ANSI.SYS color commands. I think it does because you can have color in the ls command. So such an enhanced MenuMaker would be useful for that too. But yeah the source code is available because the author put the program into the public domain.
--Brian
--Brian
