Abbub
Okay, so I've got a 5160 with the 11/08/82 BIOS in it.
I've also got an IBM Model M keyboard, which sort of 'works' with the system. (The main section of the keyboard works, but the arrow keys and number pad (when numlock is turned off) do not.
I see under the list of changes for the 01/10/86 BIOS that it includes "Added support for the 101-key Enhanced keyboard."
Will this 'fix' the system so that the Model M works completely as expected?
It seems like it'd be a worthy effort to upgrade to this newer BIOS anyway, if for no other reason than to add support for 720k 3.5 inch disks...which leads me to the next question.
What's the best method for updating the BIOS on a 5160? I assume the BIOS binaries are out on the internets somewhere. I have an EEPROM burner.
U18 and U19 both need to be burned, I assume. Both are listed as '32k' chips in the 5160 BIOS FAQ. Are chips I can burn to replace my existing BIOS readily available, or are these like the various ROM chips on the C64 that are no longer available to buy new?
Also, I assume the BASIC ROM is a different chip than the BIOS chips?
Any information and/or guidance is appreciated!
Thanks!
Thanks!
