kb2syd
Found this note:
MC68010 PROCESSOR SUPPORT FOR THE TANDY 16B/6000
XENIX/68000 Version 3.2(42a) 9 Nov 1987
The kernel in this directory will allow owners of Tandy Model 16A,
16B, and Tandy 6000 systems to use an MC68010 microprocessor of
identical speed in their CPU board in place of the standard 68000.
The kernel changes to allow this were confined to one area. They
have been heavily used on the systems used by the XENIX System
Programmers with no problems. The 68010 is completely backwards
compatible. There are no application software changes required to run
on a 68010.
At this time, however, this version of /xenix IS NOT officially
supported or approved of by Tandy Corporation or Radio Shack. The
contents of this directory are provided "as is", witout any warranty
of any kind. It is entirely the responsibility of the user to
determine whether these files should be used with the users' system.
The user shall make any adjustments or corrections necessary to use
these materials. There is no commitment of any kind to provide these
materials in a supported or unsupported form in the future.
When reporting problems with your system, make sure the problem
persists when running with the standard release of the operating
system. (Yes, you have to put the 68000 back in to run the standard
release)
Also, if you take your machine in for repair, BE SURE you replace
the 68010 with the standard 68000, or the repair folk may think it is
bad and replace it with a 68000 (their diagnostics will not run on a
68010, sorry).
This kernel was benchmarked against the regular kernel, and while
there were improvments in several areas, they were slight. It is
doubtful that any significant performance improvement will be noticed.
For a list of the differences between the 68010 microprocessor and
the 68000 consult the M68000 PROGRAMMER'S REFERENCE MANUAL, fourth
edition.
