fatwizard
I have an Epson SMD140A, 720K 3.5" floppy drive that exhibits a symptom I hadn't seen before. It works just fine until it gets about half way to the center, after which it starts re-seeking. This gets progressively worse, and will error out before it gets to the innermost track. It has this same behavior when you try to format a disk as well as when just reading from it. That suggests to me it isn't an alignment problem.
I have cleaned the heads, cleaned and lubed the relevant components, replaced the cans on the logic board, and have substituted a know good power supply. I can use a HD drive, but I can't make one look right.
Anyone run into something like this? I'm stumped at this point.
